[VENDO] - [MI] Minolta Flash Meter IV + aggiuntivo spot Viewfinder 10° II
Inviato: 05/03/2018, 19:43
*** Esposimetro Minolta Flash Meter IV + aggiuntivo spot Viewfinder 10° II ***
140 EURO
Vendo causa inutilizzo.
L'oggetto è usato ma tenuto maniacalmente, utilizzato da fotoamatore.
Si tratta di un esposimetro professionale di una precisione ineguagliabile.
Permette la misurazione della luce riflessa, incidente e spot e il collegamento
a dei flash esterni per l'utilizzo in studio.
Offre funzionalità di memoria e somma delle luci.
Dispongo di un manuale in PDF in lingua inglese ad ogni modo l'utilizzo è
molto semplice e intuitivo.
SPECIFICATIONS (riportate dal manuale)
Type: Multiple-function exposure meter for measuring ing continuous and flash light; incident and reflected
light readings possible with both digital and analog readouts on LCD panel; analyze function for readings/control
of continuous and flash lighting.
Receptor: Silicon photocell; receptor head rotates 27O°
Reception method:
Incident: Spherical diffuser (or other optional diffusers)
Reflected: 40o-angle reflected-figftt attachment (or optional Viewfinder 5", Viewfinder 10' II)
External receptors: Optional Mini Receptor, Minolta Booster II
Flash measuring ranges at ISO 100:
fncident: f lO.7 to f/90 +0.9
Reflected: f11.O to f/90 +0.9 with 40o receptor or Viewfinder 10° II; f/l.4 +0.2 to f/90 +0.9 with
Viewfinder 5°
Continuous light measuring ranges at ISO 100:
Incident: EV -2 to EV 19.5
Reflected: EV 1.0 to EV 22.5 with 40o receptor or Viewfinder 10° II; EV 2.2 to EV 23.7 with Viewfinder 5°
Measuring modes:
"AMBl": For continuous light readings
"CORD": For electronic flash, M-class flashbulbs
with or without continuous light; using flash
unit's sync cord or optional Sync Cord ll
"NON.C": For electronic flash with or without
continuous light; trigger cord not required
Cumulative readings: Possible with incident or
reflected-light readings for continuous or flash light
Repeatability: 10.1 EV
LCD digital readouts/displays:
F-numbers: f lO.7 to f/90 +0.9 in 0.1-stop incre-
ments
Exposure Index (ExlN) numbers: -15.9 to 45.6 in
0.1-stop increments
Shutter speeds: 30 min. to 1/8OOO sec. in l-stop L
increments
Frames per second for movie cameras: 8, 12, 16,
18, 24, 32, M; shutter-sectorpening of 180o
Film-speeds: ISO 8 to ISO 6400 in 1/3-stop
increments
Number of cumulative exposures: 0to 9 (displays
last digit of accumulated readings over 9 exposures
in shutter-priority mode)
Guide value (GV) numbers: -8 to 8 in l-stop
increments
LCD analog readouts/displays:
F-number scale: f l1.O to f/90 (in 1/2-stop incre-
ments)
Contrast: -4.0 to 4.O in 1/4-stop increments
(1l2-stop increments from -4 to -3 and 3 to 4)
Other: Over- and under-range signal, memory
marks (up to two), analyze function indicator
SPEDIZIONE
Data la natura estremamente delicata dell'oggetto preferirei il ritiro a mano in zona Milano
e limitrofi.
In caso di spedizione spedirò esclusivamente in Italia tramite Paccocelere 3 al costo di 12,00 euro
o Paccocelere 1 al costo di 15,00 euro.
NON MI ASSUMO ALCUN TIPO DI RESPONSABILITA' RIGUARDANTE LA SPEDIZIONE (danni, smarrimento, ecc...)!!!
Per qualsiasi altra informazione non esitate a contattarmi!!
140 EURO
Reception method:
Viewfinder 5°
Measuring modes:
ments
0.1-stop increments
increments
increments
increments
ments)
SPEDIZIONE
e limitrofi.
